Why am I seeing this in my Log file?
leo04
Just what does this mean?
2024-10-07 12:12:57.582 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(748): Formula target property not found:
File: /data/DAZ 3D/Genesis 3/Male/Morphs/Zev0/Bend Control/Smoother Stocky R.dsf
The highlight is just one of many files listed in the log...
Thanks for any help.
It usually means something you do have installed has a link to something you don't - most likely a corrective morph to make whatever is associated with the error play nicely with the morph that is not present. Sine you don't have that morph, it doesn't matter that the coirrection cannot be linked - you can generally safely ignore such warnings.
So which is which? The first or second file record that is missing?
Nothing is missing, you just don't have the other product involved.
Any idea on how I would determine what the product is and how to get it?
Which of the products listed in the warning do you not have? And why do you want to get it? This isn't a problem, it is just that the product is set with extra support to make sure it plays nicely with the other - if you don't have the other you are not missing anything, and the one you do have is working as it should (actual bugs aside)
Okay, thanks.
