Issue with PHMEyelashesCurl
I encountered an issue while saving a scene file today. At first, Daz would not let me save the file, and it directed me to check the log. The only error I saw was this:
[WARNING] :: \src\sdksource\fileoutput\dzassetoutfile.cpp(11516): No geometries match the vertex count of morph "PHMEyelashesCurl"
I was able to save the file on the second attempt, but this error showed up in the log again. Searching back through the log, I see that it crops up whenever I save a scene that includes a G8 character, male or female, although apparently today was the first time it caused a hitch when attempting to save a file. It does not appear for Genesis 8.1 characters.
Is this vertex count issue something I should worry about? If so, does anyone know how to fix it?
  • crosswindcrosswind Posts: 7,939
    You don't need to worry about it as long as this morph (Eyelashes Curl) really works if you dial / zero it. But you may try:
    - press F2, Clear DSON cache. Reload a G8F or G8M, save the scene... see if it's okay.
    - if the issue persists, completely uninstall Starter Essentials packages and reinstall them via DIM.
