Is there a shorcut to back and forth from main layout to viewport only?
I find it's more quicker to work with mulitple viewport, instead of just one.
I imagine of let's say I have the default layout, then I can switch to let's say 3 viewports without any panes. back and forth.
  • crosswindcrosswind Posts: 8,006
    Yes, you can use Activity Bar.
    Enable Activity Bar under Windows > Workspace. Press F3, add more Activities under Activities tab. Then configure Layout in each activity with different Viewports / Pane groups setup, as well as Styles.
    Then in F3 > Actions tab > Workspace, assign shortcuts to Show Activity 0 ~ 9. Then turn off Enable Activity Bar if you want to have more space... It's up to you. Remember to save your Layout then.
    2560 x 1392 - 198K
  • barbultbarbult Posts: 24,820
    That's a good tip.
    barbult said:
    That's a good tip.
    Thank you, barbult !
  • JamesJames Posts: 1,103
    edited October 2024
    I'm having a bug.
    When changing activities pane, daz get shuts down by itself... :(
    I'm using 4.23 version.
    The previous also the same.
    And why the viewport background color on the new activity pane is black instead of grey ?
    I've found the solution. Make the changes, shut it down, and open daz again. There's no problem.
    Anw, thank you for the information.
    Post edited by James on
    Great!
