GOZ for Daz 4.23
![nsk001](https://secure.gravatar.com/avatar/e9e12b8062e4d95b952abc99a4cd738b?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fe9e12b8062e4d95b952abc99a4cd738b_100.png)
I downloaded Daz Studio 4.23 but GOZ is not available for download.
There is only GOZ for Public Build but it doesn't work with the main version
This discussion has been closed.
Right ~ you can fill a ticket... But older version of GoZ also works in newer DS version, you still can use it for the time being.
Same problem here - but I found a solution: Load your UI from Public build into General with the "Copy_UI_From_Channel" script from brilliant Richard Haseltine (https://www.daz3d.com/forums/discussion/comment/8880326/#Comment_8880326). Now GOZPublic build works in the General release.
Your other post has been removed - please don't post the same thing in multiple places.
You may have only one channel of GoZ installed at one time, so you need to pick beta or general release. I am seeing both in DIM, though I usually keep one hidden to avoid accidentally swapping which is actually installed.
I won't dispute that the author is brilliant and has a name beginning with R, but it isn't me.
