Animated Surface parameters
jmucchiello
in New Users
Is it possible to animate the surface parameters of a figure? Say I want something to fade in or fade out. In my mind, you go to the surfaces of the figure. Set the opacity to 100 on frame 1, set it to 0 on frame 10, and animate should fade cause the figure to fade.
But it doesn't. Is there a tool for this?
Directly, no, but you can link a material property to a node proeprty - and that will animate. This needs to be done via a script, see
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/elements/post_load_material_proxy_create/start
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/elements/post_load_material_proxy_link_properties/start
