Renderhub zip
chrisvnchrisvn Posts: 54
edited October 2024 in New Users
Hello everyone
I tried to install a character purchased on RenderHub and I managed to get the body and the mesh skin and everything else tells me that there is an error and that I need to look at the log for more detail! Except I'm not the log either
for the installation of the files I unzipped the inside of the content folder of the Marcus renderhub zip in (A:\Daz 3D Folder\myLibray\Applications\Data\DAZ 3D\My DAZ 3D Library\People\Genesis 8 Female\Characters \Marcius)
I am attaching some PJs to you
I'm really bothered plus it's a character that I'm going to use for an animation project for my exam
Thank you for your help
1920 x 1080 - 224K
1920 x 1080 - 210K
«1
  • That is ashaping preset - you need to load the base figue and have it selected for shape and materials presets.
  • lilweeplilweep Posts: 2,550
    edited October 2024
    Yeah, you probably shouldnt just be inventing your own installation methods and unzipping random files into random locations in your content folders
    https://www.youtube.com/results?search_query=install+3rd+party+content++daz+studio
  • chrisvnchrisvn Posts: 54
    edited October 2024
    For that I don't really know what a shape preset is - and I already had difficulty doing what I did so load the base figure and select it for the shape and material presets, I don't know how to do that , It shoud be probably as said Lilweep, i heve interverted my installation i will see the link youtube
    why are we posting like this
    There are many different types of presets, material preset, shaping preset, full character presets.  Shape preset is, as the name implies, is a type of preset that applies the shape of a character.
    To use a shaping preset, you need to add Genesis 8 female in the scene first to be able to apply the shaping preset to it.
    Because when text is pasted in from certain sources, including a Google Translate box, it appears in Formatted rather than Normal format (drop down button just before the text colour button - and the forums have taken to showing that format in that way. Switching the format to Normal will resolve it, which is what I have done.
    Thank you richard I selected normal in the drop-down menu.
    Lilweep : I just try to add Genesis 8 female in my scene and i can't apply the prereglage, i heve follow the tutu :
    I admit that I don't understand, I'm going to follow another one to see !!! so i will tel to you Thank for the help
    1920 x 1080 - 236K
    I only linked those tutorials because you implied you installed the files incorrectly, but I wasn't sure if that was your issue.
    Can you state what the problem is? Has the problem changed? Originally you were getting an error, what problem is the latest screenshot showing? It doesnt seem to be showing any issue?
    My problem is that I have a character that it comes from the RenderHub Website, I can't apply it, even if I Add Genesis female 8 body firts
    edited October 2024
    It would need to be the highlighted selection in your 'Scene' tab before applying the preset.
    Another way to apply morphs is via the 'Parameters' tab.  You could go to 'All' in 'Paramaters' tab and type 'Syph' in the Search bar.
    Post edited by lilweep on
    edited October 2024
    I wanted to try this evening but suddenly I uninstalled them all last time! to be transparent in the way I installed I will tell you where the files go and you will tell me if it is correct :
    so the folder : «data / People /Runtime» I take them one by one and I drag and drop in folder My DAZ 3D Library»  is correct ?
    Thanks for your help
    Post edited by chrisvn on
  • felisfelis Posts: 4,606
    You can drop them one by one, but that can be rather tedious. And you need the full structure. E.g. inside the Data folder there will be a deep structure that must be copied.
    You should be able to just drop the 3 folders, on the library folder that has Data/People/Runtime, and then the individual files will get merged into the structure, and it will create new folders as needed.
    It is essential that you drop them on the library folder. If you e.g. instead drop the Data folder on the library Data folder the product Date folder will be included in the library so you will get Data/Data/.... and that would cause errors.
    edited October 2024
    ok I understand and yes, that's exactly what I did data file in data etc....well so now I end up with errors! I'm going to have to reinstall daz again?
    Only the affected content, at worst.
    I confirm what you sed ! I didont fine anymore install manager and i have another caractère i can't open !!! i will install again daz or maibe firt i will desinstall all pluggin and Addon first and réinstall !!! I comming back this weekend ! Thank you again for your at everbody help realy i'm glad
    Basically, yes.
    Note:
    It doesnt need to be one by one. You can select all and drag/drop all at once.
    You can merge them into any of your content libraries. If 'My Daz 3D Library' is the content library you want to install to, then yes it can go there.
    I have a content library specifically for each online store. For example, I have a content library for Renderhub. That way it's easier to remove content from this library.
    If you want to add a new content library, it's easy.  In DAz Studio, under content library tab, you can right click Daz Studio Formats and add a new one.
  • Note that in MacOS you do need to be careful as it will replace one identically named folder with the other, rather than merging them as Windows does.
    lilweep said:
    Basically, yes.
    Note:
    OK Thank You I will try again
    I'm working with Windows
    lilweep a dit :
    chrisvn a dit :
    donc le dossier : « data / People / Runtime » je les prends un par un et je glisse/dépose dans le dossier « My DAZ 3D Library » est-ce correct ?
    En gros, oui.
    Note:
    Je les prends un par un
    Il n'est pas nécessaire de procéder un par un . Vous pouvez tout sélectionner et tout glisser/déposer en même temps.
    dans le dossier Ma bibliothèque DAZ 3D
    Vous pouvez les fusionner dans n'importe laquelle de vos bibliothèques de contenu. Si « Ma bibliothèque Daz 3D »  est la bibliothèque de contenu dans laquelle vous souhaitez effectuer l'installation, alors oui, vous pouvez y placer vos fichiers.
    J'ai une bibliothèque de contenu spécifique pour chaque boutique en ligne. Par exemple, j'ai une bibliothèque de contenu pour Renderhub. De cette façon, il est plus facile de supprimer du contenu de cette bibliothèque.
    Si vous souhaitez ajouter une nouvelle bibliothèque de contenu, c'est facile. Dans DAz Studio, sous l'onglet Bibliothèque de contenu, vous pouvez cliquer avec le bouton droit de la souris sur Formats Daz Studio et en ajouter un nouveau.
    OK so i will try to create a new spécific folder is good idee also thank you hope after it will be ok !!
    edited October 2024
    lilweep said:
    Basically, yes.
    Note:
    ok it's easy when you know! I thought so too at the time! but no, I don't know Abglish, it's not my first language!!! so I have a lot of trouble
    998 x 1080 - 88K
    lilweep said:
    Basically, yes.
    Note:
     Look on PJ, it is Here ??
    3600 x 1080 - 440K
    No, not there.
    Right click Daz Studio Formats > Add Base Directory.  Then you could link to a folder on your harddrive where you want to start adding 3rd party content.
    Do you still have the products installed in your other directories? If you do still have the content installed in another directory, it could cause some conflicts.
    edited October 2024
    lilweep said:
    No, not there.
    Hello ,
    I created a Daz folder on a separate hard drive and in this folder I created subfolders;  a daz_Source folder, another instal_Manager_Source folder, and a folder for the library, it is ok ?
    Yes naw i saw for the directory !! but the question is, did I do the right thing by separating daz, install manager, and the library?
    If you are doing manual installations, you only need a content library, i.e. one folder you can refer in Daz Studio content management.
    All subfolders will be created along the way, if you just dump the content of a zip file on your new content library.
    If youre asking if you can have multiple content libraries for different purposes, the answer is yes.
    If youre asking something else, i have no idea what you are trying to ask.
    lilweep said:
    here is a screenshot of my file how it is organized! I want to know if it's ok like that if I don't risk having a conflict ? :
    1376 x 624 - 43K
    lilweep said:
    I didn't have too much time I'm going to put it back this weekend, thank you my question is is the way I organized my files correct ? (see on the PJ)
    1651 x 848 - 55K
    You have 3 folders, but it is unclear what the purpose of those folders are:
    dossierDaz_source: ?
    Installmanager_source: ?
    myLibrary: your content library.
    What lilweep said was that you can have more content libraries, e.g. one for Daz content, and one or more for content from other shops.
  • chrisvn said:
    Hello everyone
    Will this YT video help with installing content purchased elsewhere?
    https://youtu.be/xNgcZDlFyJw
    Daz_source is the folder where daz is installed , Installmanager_source is the folder where install manager is installerd and my library is the floder where my library is installed ....
