Go back to previous edition? Navigation/shortcut issues.
Is it possible to go back to the previous edition of Daz Studio? The 4.23 update has absolutely wrecked my workflow. None of my shortcuts work any longer. Zooming in or panning take forever. I used to use my TourBox with Daz to navigate in the viewport and now none of that works any longer.
If I have a large environment open in the viewport, it's almost impossible to navigate because the zoom and panning barely work.
Am I alone in this?
  • Richard HaseltineRichard Haseltine Posts: 100,941
    That sounds as if soemthing happened to your layout files. You might check
    %appdata%/daz 3d/studio4/
    and se if there are temporary back-ups of the ui files, though if there were I suspect they would have been overwritten when DS next ran. Do you haev backups of that folder? Failing that, load the layout you used as a basis for yours (WindowWorkspace>Seelct Layout - which will also have any layout you saved).
