spinning a sphere 360 in 210 frames? spins backwards after 180
goin nutz all day, >.<
i set the keyframe for the sphere with rotation 180, looking good so far.
when going the last frame i try entering 359, but it turns into negative 1 and the sphere spins backwards.  >.<
trying to make a very basic seamless gif loop.  without moving the camera.
don't know what to do?
thanks!
1094 x 622 - 109K
1084 x 583 - 105K
1084 x 583 - 105K
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,375
    Try using the spin modifier
    well, but this is a learning exercise to rotate an object in sequencer
    next trick is to get it to spin along a motion path smiley
    should i put in support ticket?
    edited January 2016
    I can get it to work keyframing but is tricky
    spin modifier is just so much easier
  • de3ande3an Posts: 915
    edited January 2016
    Set your object's "Rotation Controller" to "Angles", and you will be able to use rotation angles higher than 180 degrees. (see image)
    254 x 441 - 58K
    Post edited by de3an on
    wwoww thank you!!!!
    Glad to help. smiley
    edited February 2016
    is there a way to morph a normal round orbit into elliptical orbit
    https://en.wikipedia.org/wiki/Elliptic_orbit
    was thinking like an electon orbiting nucleus animation
    ironically, i failed geometry twice in high school
    Post edited by Mistara on
     thinking cap on.  Maybe find some way to combine (1) a central vertex sphere, and (2) a second sphere that is soft body attached to the first sphere at a tangent {but have the soft body settings very rigid so it keeps it shape}, and (3) spin the central sphere, and (4) make the spinning central sphere invisible (uncheck visibility or use an alpha shader).  OK, I think so far, the second sphere will appear to be rotating in a circular orbit.  How to make the orbit shape expand and contract in time for an ellipse?  Maybe (5) for the first sphere go to the modifiers tab and choose formula.  Make the axis upon which the softbody attach has been placed augmented by the parameter P1.  Then (6) make P1 a function of time synchronized to the time it takes the central sphere to complete a rotation.
     Sort of depends upon how the softbody interacts with distortions caused by a modifier on another object.  But it might work.
  • bighbigh Posts: 8,147
    look at the planets animation - you got with Carrara
    planck's constant?
  • fixmypcmikefixmypcmike Posts: 19,587
    MistyMist said:
    planck's constant?
    he was the last time I looked.
    mebbe that graphie thingie?
    cant stay awake anymore tnite.
    ironman dreams, 2.39:1  Panavision ratio,  2048×856 pixels  https://en.wikipedia.org/wiki/Digital_cinematography
  • RoygeeRoygee Posts: 2,247
    Simple - Give the sphere rotation, set motion to motion path.  Draw eliptical orbit, let it run then change motion back to keyframes.  Make animation group, make NLA, looping:)
    the angles think did the trick for the rotation, plugged in 720 for an extra spin.
    don't know what i did to make the infinite plane shader change.  looking through the triangles in sequencer
    haz to be a more logical way to elliptic orbit
  • DesertDudeDesertDude Posts: 1,238
    I just tried a simple set up similar to yours. I used a cube and a sphere, made the cube a child of the sphere, and moved the cube some distance from the sphere. I created a circular orbit for the cube by spinning the sphere 360 degrees over 4 seconds. Then, to make it elliptical, at 1 second and at 3 seconds I moved the cube closer to the sphere. I also had to move the cube back "out" at 2 seconds to create an elliptical path. I had to smooth out the keyframes in the Graph Editor because the cube made a weird "bounce" at the 1 second and 3 second keyframes. Not sure if this is a super precise method...
    800 x 800 - 148K
    the graphie thing is pretty mysterious
    Instead of animating from 0 to 360, try animating from -180 to +180
