Converted hair no longer works in Daz Studio 4.23
I finally decided to make the move to G9 after purchasing clothing, hair, and pose G8-to-G9 converter utilities.  After getting all the clothes and hair converted, I just found out that none of the converted hair works anymore.  When I click on a hair item, it no longer attaches to the head, but all sorts of random places on the body instead.
  • felisfelis Posts: 4,551
    Are the converted hairs that don't work strand based hairs?
  • You may be on to something there.  I never got into the technology behind hair and never understood what technologies are being used.  I have assumed that when I see what appears to be individual strands of hair, that is "strand-based".  With that idea in mind, I assume that Out-of-Touch hair products are strand-based, and from what I see, most of their hair works. (Their 2022-03 or 2022-04 Hair doesn't work, though, although I haven't gone through them all to know what others don't.) Lenny Hair by Propschick doesn't work, and yet that appears to be strand based, but I don't know for sure.  Propschick's Mallory and Fiona hair doesn't work either and I don't know what type of hair those are. Goldtassel's hair products that I converted seem to be hit or miss.
    I only recently converted all my hair products, I think over 200 of them, and didn't test them all after I found all the ones I tested were working. It is possible that the ones I found not working after the VS 4.23 upgrade weren't working before the upgrade.  When I posted this thread, I was finding that virtually every one I was testing was failing, but it seems now quite likely that was just due to too small a sample.
    It is really a pity how many hair products don't work for G9 even with the conversion utility, but I guess that I have to live with it.
    Thanks for getting back to me on this.
  • Update:  I had used the RSSY G8-G9 Hair Converter to do a big batch conversion on all my hair assets.  Many worked properly, but as I said above, many were attaching to other parts of the body instead of the head.  I'm still not sure if anything being "strand-based" is the issue, but I think I may have solved the problem.  All I have to do if the hair attaches to a part of the body instead of the head is to simply right-click on the hair in the Scene panel and select "Fit xxxx-hair to 'none' ".  Doing that causes the hair to instantly attach to the head.
  • GordigGordig Posts: 10,119
    OoT makes it VERY clear when their hairs are strand-based, and they only started making strand-based hairs in the last few months.
