Neither update nor uninstall
2Za
Hi everyone,
I have a problem with some products (see attached file)
As mentioned, once these items are installed, the little icon indicating that a product update is available does not go away, and in the context menu it is neither possible to update nor uninstall the item. Is this a display bug? Or something else?
I also have this problem with Oso Toon Shader for Iray, Toon Makeup System - Vicky 9 Makeup and Wàonderful Anime Poses for Genesis 9.
Thanks in advance for your help!
483 x 1326 - 501K
That isn't the update icon, it the available to install through Connect icon (presumably you installed through DIM). Daz Studio can't uninstall content installed through DIM.
In 4.23.0.1 you will not get that marker.
Hello Richard,
Thank you for taking the time to inform me, I was totally unaware of this (I'm a newbie) I uninstalled via DIM then reinstalled in DAZ, indeed now I can uninstall and the icon has disappeared.
Thank you very much, it may not be a big deal but it was stressing me out xD
Really? I'm away from my system till tomorrow, but I've seen that marker on items where there seems to be two copies. The one installed by DIM and the one not installed but waiting to be installed through Connect, even though those are the same item. It seems to happen when DIM sys there's no metadata for a package.
