I would like to know if I can undo the button on jeans.
seongilkim0107seongilkim0107 Posts: 17
Hello DAZ3D users.
I'm leaving a question here because there is a limit to the product description.
I'd like to know if it’s possible to undo the button on the jeans.
Simply put, can the button be fastened and unfastened when dressing or undressing?
If anyone knows, I would really appreciate your response. Thank you.
https://www.daz3d.com/genesis-8-female-mega-wardrobe
  • ElorElor Posts: 1,777
    edited October 2024
    They are 6 open morphs on the jeans, looking like this (default G8F in her default pose with the jeans using FitOverShort morph at 100% because I used the short part of the product too)
    Default (with the shortest setting for them, but they will look exactly the same with the other length: it's the same object):
    Open 1
    Open 2
    Open 3
    Open 4
    Open 5
    Open 6
    If you want to have the short under the jean, with some open morphs, setting the short as the Mesh Smoothing target of the jeans instead of Genesis 8 will fix most pokethrough but in the most extrem case (Open 6), dialing Adjust-Hip to something like 20% added some improvment (you'll likely have to adjust the value depending on the pose you'll use: here I only used the Genesis 8 base pose):
    1600 x 1600 - 331K
    1600 x 1600 - 332K
    1600 x 1600 - 331K
    1600 x 1600 - 328K
    1600 x 1600 - 328K
    1600 x 1600 - 314K
    1600 x 1600 - 301K
    1600 x 1600 - 301K
    Post edited by Elor on
  • richardandtracyrichardandtracy Posts: 5,765
    edited October 2024
    The pockets also open, which is very useful for putting hands in pockets:
    (Fingers only = 40% open, hand in = 100% open)
    Regards,
    Richard
  • Moved to technical help as it is a question about an exiting product, not a suggestion of a product to be made or a search for a product of a certain type or an identification request.
  • Thank you so much for the detailed explanation. It was very helpful.
  • Thanks a lot Mr. Richard.
