DAZ 4.23 refuses to open.
Hello, i´m a newcomer to this community and i installed the latest version of DAZ a few days ago. For whatever reason, every time i click to run the loading page pops up but then it disappears. Not even in the task bar it appears. Just now i uninstalled it and reinstalled everything yet the problem persists.
I seriously do not know what to do at this point.
  • memcneil70memcneil70 Posts: 4,309
    The first question the experts will need to know is what type of system are you on, Mac OS or Windows? Which version of DAZ Studio did you install? 4.23.0.?
    The last I heard there is an issue with the Mac version of the DAZ Studio 4.23, but the DAZ Studio Public Build Beta does work on Mac's. Should be no issues with Window versions. But, MacOS versions are prone to crashing at times, especially if you have an M1 - M3 chip.
    I can't help much beyond this, so hope others will look in.
  • The first question the experts will need to know is what type of system are you on, Mac OS or Windows? Which version of DAZ Studio did you install?
    That´s true, absolutely forgot about it apologies. I installed the Windows version, if i´m not mistaken it´s 4.23.0.1.
  • I've had this happen from time to time. Most commonly when I accidentally close Daz (or it crashes) and I want to reopen it again. Click on the icon, the splash screen appears, then vanishes.
    The only thing that's ever worked for me is to give it a few minutes before clicking on the icon. That seems to work every time.
    I'm assuming it's a memory issue? I wonder if the PC/Daz needs to purge bits and pieces from RAM to leave enough space for a fresh version of the program to load up?
    With that in mind, seeing as how your Daz seems to never load, how much memory does your system have?
  • From what i can see here, It has 51,8 GB left of memory.
