Question on DzProductAssetContainer.addAsset
If I select an asset in the content library and use “create product from”, I can add my asset to any existing product.
If I use DzProductAssetContainer.addAsset(), I can only add assets to products that I have created manually.
How can I add an asset to any product regardless of whether it was created manually or installed?
  • Richard HaseltineRichard Haseltine Posts: 101,482
    Vendor data vs. user data, with the complications hidden when using the UI?
  • kabexefkabexef Posts: 77
    It works via DzAssetMgr.createProductFromAssets() ... but now I can't remove the asset from the product via DzProductAssetContainer.removeAsset().
    I am not seeing an addAsset member - there is an insertAsset member.
    edited November 3
    Sorry, my fault. The insertAsset() won't work for any product. DzAssetMgr.createProductFromAssets() will work for any product ... but now I can't remove the asset from the product via DzProductAssetContainer.removeAsset().
    Post edited by kabexef on
    Do other members of DzProductAssetContainer work as expected?
