G3/G8F skirt or miniskirt that undoes from the side
So I want to find a miniskirt or normal sized skirt that undoes from the side or back or anywhere via buttons or zipper or whatever so its elongated once its undone. Any suggestions? Thx.
  • felisfelis Posts: 4,595
    I am not sure what you are asking for.
    Could you post an image.
    Or is it actually a skirt/miniskirt that can be opened you are after?
  • ToobisToobis Posts: 966
     yes a skirt miniskirt that can be opened.
    edited November 2024
    Opened full or just partly?
    I would assume most only open partly.
    Would something like this work?
    2000 x 1600 - 5M
    Post edited by felis on
    Sorry for late reply but yes basically anything that opens partly or fully.
    The skirt is attached.
    It is intended for dForce. dForce is also needed to open it.
    Default the skirt will just act as a normal skirt. It is made for G8F.
    To open it you must do the following step.
    - Change 'Dynanic Strength' in Zipper surface settings to 1.
    - In morphs, activate G8F_Shirt_06_Skirt_open. (It will open it slightly, but if not done, then dForce will make the clothing dissappear)
    - Simulate
    - After simulation move the zipperhead to the wanted position. (It is attached with a rigid follower node, and I am not aware that there is other ways to do it.
    It is not a one-click solution, but I couldn't find a way to do it (I would think a script might could do it, but I have never written scripts in Daz Studio)
    If you further want the skirt to fall down, you need to add a push modifier. I realised that even open, the skirt is so tight it will not really drop. (You can also do parameter changes in simulation timeline, to make it drop, but it requires a better understanding.)
    Let me know if issues.
    Just a little fun
    How it looks simulated with push modifier set to 1 (default)
    1600 x 1000 - 2M
    2000 x 1600 - 3M
    zip
    zip
    G8F_Shirt_06_Skirt.zip
    5M
