3Delight Renderer
AVU4UAVU4U Posts: 67
Anybody have any experience with using 3Delight to render on multi core computers? From what I can tell the 3Delight renderer that comes free with the Daz4 program only uses 1 core. I've got a first generation MacPro dual processor 8core machine running OSX 10.6.8. The renders I'm making take forever. Would purchasing a 3Dwlight multi core rendering engine speed things up? I looked at the 3Delight website and I didn't see that it has much support for its users. B4 I spend hundreds on the 3Delight I thought I should get some reviews from Daz4 owners using multicore 3Delight render engines to render their Daz4 scenes. You can see the renders I've done so far with the free version of Daz4 using the one free 3Delight render engine at the following links. These renders take a long time and since I'm probably going to have about 1200 of them in my upcoming graphic novel NOCTURNES I need to speed things up a lot. Check out the links here:
Nocturnes by AVU4U
http://www.daz3d.com/forums/discussion/519/
Club Street in the graphic novel NOCTURNES
http://www.daz3d.com/forums/discussion/520/
Z Nightclub interiors in the graphic novel NOCTURNES
http://www.daz3d.com/forums/discussion/524/
Here are some renders of the mighty Z Nightclub and Club Street in my upcoming graphic novel NOCTURNES. The work that I have put into these renders taught me how to do UV maps in Lightwave and then export them to Daz4. Doing this is not easy. I’ve been working on the Z Nightclub for over 3 months and its almost finished. Hopefully I’ll get it done next week and then I can begin to build the interior of the BANK Nightclub which is across the street from the Z Nightclub. If everything goes well I hope to have the graphic novel NOCTURNES done in about a year from now.
I have a couple of more interiors to finish once the BANK is done and then I can begin to design the characters. The illustrations in my graphic novel Nocturnes will probably exceed 1200 with a projected page count of about 300. I’ve never done anything like this so wish me luck. Daz4 rules.
  • fixmypcmikefixmypcmike Posts: 19,597
    The 3delight in DAZ Studio should use all available cores to render.
  • Kendall SearsKendall Sears Posts: 2,995
    The 3Delight version included in the DAZ Studio install will use all available cores. The standalone version will use a maximum of 2 cores unless a commercial license is purchased.
    Kendall
  • Wiccan1Wiccan1 Posts: 198
    Make sure your using the 64 bit version, on a 64 bit platform, to get all the cores available. On my Win7 64 bit machine, I get all 8 cores.
  • frank0314frank0314 Posts: 14,247
    You can also allocate the number of cores you want DS to use if it is bogging your system down.
    Open your Task Manager, select processes, scroll down to DAZStudio.exe, Right-click on it and select Set Affinity, then uncheck till you get the number of cores you want allocated to it.
    You will need to do this every time you run DS unless you write a script to do it for you.
  • Testing6790Testing6790 Posts: 1,091
    On this topic, are there other renderers that can be used in DAZ Studio 4? I'm not a fan of how the renders look almost exactly like screenshots of the preview pane. Maybe something like lux renderer?
    If you render to "RIB" from the render settings tab, you can import the data into another Renderman compliant renderer. There may be issues with pre-compiled shaders and paths for assets. This can somewhat be mitigated by checking the "Collect and Localize" option.
    Otherwise, the Reality plugin will let you render using Luxrender, and there are plugin that allows rendering in Octane and Blender's "Cycles" Renderer.
    Kendall
  • RenpatsuRenpatsu Posts: 828
    Not sure if this applies to you, but are you sure you are using "Software Rendering" (and not OpenGL)? Also light / material setup plays a large role on how the render looks like.
    Either way, when I am using the 3Delight render engine, the render does not look like a screenshot of the preview pane at all, not even close.
  • AVU4UAVU4U Posts: 67
    Here is the link for both Windows and Mac (which I use) that shows how to set the computer up to use all available cores.
    http://docs.daz3d.com/doku.php/artzone/pub/software/dazcms_check
    Ah that must be it, being new to DS I haven't played with lighting or shaders yet, and most materials I use are low res
