G8 geografts on G9
![Fantozzi](https://secure.gravatar.com/avatar/f7e6fe46d4126bf66e6ef6aebf9d8384?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Ff7e6fe46d4126bf66e6ef6aebf9d8384_100.png)
Hello,
with the help of a tutorial I could make a geograft figure from G8 to work on G9. But now I'm stuck with the UVs/textures. Not shure with the legacy UVs from Cayman Studios. Do they work only on the original figures or would they work on the single geograft only taken from one figure to the other.
And the most stupid question - which one would I need if it works if I use a g8 geograft on a g9? I need to put the g9 textures on the g8 geograft - so I need the g9 UVs for g8 - even if my figure is g9 only the geograft has g8 uvs. Right? .
You'd need to make your own UVs, the tools like Cayman's sre for using (in this case) Genesis 8 maps on Genesis 9 - but they affect only the figure itself, not add-ons.
That'll depend on the UV that the geo-graft uses as well as the way you used to convert / fit a G8 geo-graft on G9.
1) 1stly, if the converted geo-graft on G9 still use the same UV from G8 ( checkt its UV layout ), Cayman's Legacy product will do.
2) 2ndly, you did't mention which G8 geo-graft you used and the way you fit it on G9... but as long as you didn't make the geo-graft from adopting the geometry on G9, you would not be able to use any UVs of G9 on the graft. Besides, if you re-modeled the G8's geo-graft, you would have to unwrap its UV make a new one...
