Disable Viewport Updating
I want to do heavy process, so viewport shouldn't be referesh/ updated, until the end.
any context or command to do this?
  • HowieFarkesHowieFarkes Posts: 607
    edited November 2024
    I like to wrap this around any code that will potentially be slowed by the viewport being refreshed
    bool locked = dzApp->getInterface()->getViewportMgr()->isRedrawLocked();
    if ( !locked ) dzApp->getInterface()->getViewportMgr()->lockRedraws();
    // your code here
    dzApp->getInterface()->getViewportMgr()->unlockRedraws();
    dzApp->getInterface()->getViewportMgr()->repaintActive3DViewport();
    Post edited by HowieFarkes on
    // your code here
    Thatv is SDK code, this is the scripting forum.
  • DS 4.22.1.88 (so present in the ciurrent General Release) added script features that should help:
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log_4_23_0_1#4_22_1_88
    // your code here
    this is great! thank you!
    script forum and sdk forum tied together,any code sdk code can be converted to the script code:
    App.getInterface().getViewportMgr().redrawsLocked(false)
    what part might help?!
  • Not all SDK features work in Script and vice versa.
    In any event, in this case using the SDK calls is risky - if the script crashes out, or simply fails to complete the unlock step for some reason, then the Viewport can be left locked - the calls mentioned in the chnage log will unlock automatically when the script ends, so there is no risk of leaving the Viewport locked.
    beginViewportRedrawLock()
  • Aha, Thank You!
    so code should be
    process...
    dropViewportRedrawLock
    what clearViewportRedrawLocks does?
  • I'm not sure, but it may be clearing all locks while the other two target only the active viewport.
  • OK, i just want to confirm that beginViewportRedrawLock does the job perfectly.
    I call clearViewportRedrawLocks at the end, until we found the official documentation.
  • Richard HaseltineRichard Haseltine Posts: 102,109
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/global (I think this is brand new, I did look earlier - for what little that may have been worth)
    I think the idea is that you can stack mutliple locks during a script and they will not release until all are removed or the clear command is used to remove all of them at once - useful if you might soemtimes want the viewport to update, subject to coinditoons - but if you have just one lock at the beginning it doesn't matter whether you clear or drop (or indeed just exit the script, though that would be sloppy).
