What would cause a single G9 figure to swamp memory?
What would cause a single G9 figure to take up 40.9 GB of computer main+virtual memory and 10.54 GB of GPU memory?
I am running DAZ3D 4.22.01 Pro edition 64-bit public build on a windows 10 box with 32GB ram and an NVIDIA GeForce RTX 4070 Ti 12 GB.
To render this figure, I can be doing nothing else on my computer at the same time. I discovered the problem when renders were aborting with GPU out of memory errors. I have rendered many hundreds of g9 figure images on this machine as described. I've never had this problem before. I am unable to discern from the log file why this is happening.
What could be causeing this one figure to swamp my momory resoruces?
  • barbultbarbult Posts: 24,832
    Render Subdivision value too high, for one thing.
  • Thank you, Barbult! That appears to have been the problem. The minimum subdivision level had been pushed up to 8! I do not know how that happened. Probably a slip of the mouse. I sent it back down to 3. Now it is using 16 GB of main memory and about 6.55 GB of GPU memory.
    Great to hear that you resolved the problem!
