How to Remove Unwanted Makeup Elements from a Skin Texture?
I found that one of the products I purchased includes a character's face texture that already has eyeshadow, hair, and eyebrows, but in fact, I don't need these elements. Is there a simple DAZ method or product that can help modify these small imperfections on the face texture? (I suspect Photoshop could do this, but it seems too difficult for me.)
Thank you.
  • crosswindcrosswind Posts: 8,015
    Something like eyebrows could be removed by Brow Remover As for removing makeups... not easy, even in Ps.
    Thanks for your answer, this product looks great.
    Regarding removing eye shadow, I only found the method of using Ps Clone Stamp Tool, but when I actually used it, I found it quite difficult to operate, and it would make the color and texture of the eyelids weird. crying
    The pre-requisite of using a Clone Stamp in your case is that there must be an area of eyelids on which there's no makeup. However, on the texture map as you mentioned, that area is alrady covered by an eye shadow ~~
  • ZiconZicon Posts: 354
    The only easy solution to this is using a different skin texture. Every other solution requires significant time, skill and effort.
    Thank you sir, it is exactly as you said.
