Looking for a White Scarf for Genesis 9 (Male)
Can anyone help me find a White Scarf or Scarfs that have a white colour option?
See attached pics as an example.
Thank you in advance.
500 x 650 - 32K
2000 x 2600 - 4M
  • PlantPlant Posts: 126
    you can make a scarf white by selecting it , under surfaces select diffuse overlay weight, turn up to1.under diffuse overlay colour put what colour you want
    edited November 2024
    dforce-indian-scarf   Has a good selection  or just put scarf in the search for more.
    Post edited by Plant on
  • n.aspros123n.aspros123 Posts: 207
    @Plant  I clicked on that link and it comes up with an error.
    I've done a search using Scarf and it doesn't come up with much for G9. I was wondering if there's scarfs included in clothing packs but not shown in the thumbnail image of the packs?
    1344 x 934 - 105K
    Post edited by n.aspros123 on
  • Phoenix1966Phoenix1966 Posts: 1,714
    Try this link: https://www.daz3d.com/dforce-indian-scarf
    @Plant added a semi-colon accidentally, which messed up the link.
    Post edited by Phoenix1966 on
    It works on any figure i just tested it on gen 9
  • crosswindcrosswind Posts: 8,023
    The scarf from the 1st promo comes from https://www.daz3d.com/dforce-titan-clothing-set-for-genesis-9 Then remove texture map in Base Color slot and give a while or light grey color. Add some value to Diffuse Roughness slot.
    Or, better use some good shaders (ss1), e.g. https://www.daz3d.com/mmx-knitted-fabric-patterns-4-for-iray as the tex. map from that product was not well made...
    Then thicken the scarf by using Thickener plugin because the geometry of the item was not well made either... too thin.
    Besides, some scarfs for G8 can be loaded on G9 by using Auto Fit. So don't limit searching products for G9 only ~~ (ss2)
    2560 x 1392 - 1M
    2560 x 1392 - 2M
    Post edited by crosswind on
  • @crosswind
    Thank you for your valuable information. I have not gotten around to working on scarf. It's been hot, located in southern hemisphere and I've been sick with COVID.
