Camera tilt
![linoge8888](https://secure.gravatar.com/avatar/b0b6f143f27e348f5341e149c29e92e8?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fb0b6f143f27e348f5341e149c29e92e8_100.png)
I want the camera to rotate on itself perfectly like CTRL+RMB+drag is doing at the beginning, but the camera animation is mediocre. How to fix, if it's possible ?
You can add more keyframes in between the starting / ending frames (e.g. 10 frames per interval), i.e. insert a Keyframe then Bank the camera. Repeat this action from the starting frame to the ending frame.
Well, I did that first but the result is far from being as fluent as intended. At this point I should add keyframes on each of the 65 frames but it would be pretty impossible to reach an impeccable fluency.
It is a very commonly-used technique that can make the banking / dolly etc. work smoothly with animated range, as long as you do it correctly....
I used 15 frames interval as an example: https://mega.nz/file/uGhDGABa#EAzVR7ZGp93425ka2j3ddmYhSRu3Hltl02qOS5xkloU
Yes, it's doing the trick, although not perfect. Thank you.
