I got some assets from Render hub and tried to manually install them by the video here on Daz
I got some assets from Render hub and tried to manually install them by the video here on Daz by the video on the front page and it messed up my liberty and the assets are not loading is there a way to restart it from like the beginning before I messed it up?
any help is much appreciated.
  • Mac or Windows? Which video, and what is now happening with your content library?
  • windows
    https://www.youtube.com/watch?v=wq_NkRRSc3E&t=2s
    when I go to access it it says the file can not be found and has a yellow dotted box around it
  • In which pane? Please post a screenshot, and also a screenshot showing where the file is on disc.
  • here are the photos if you need others then I will send them
    but that is how it is for all my assets are
    155 x 188 - 6K
    465 x 383 - 26K
  • OK, so the first shows that both thumbnail (the exclamation in a frame) and file (the exclamation at tlower left) are missing from where DS thinks they should be. However, the second doesn't show where the file actually is (or should be) on disc. Given that you appear to be under Daz Studio Formats, which is usually based on files not database entries, I suspect you are looking in the Daz Connect virtual content directory in which case the system showed you had installed that way (through Daz Studio itself) but the files have been removed or the directory is no longer mapped.
  • ok thanks
