Navel HD Dials not saved
iceltyllc7739589
So, can anyone explain why it is - and just to clarify, this only happens with the Navel HD morph - that every time I load the same scene after saving a Genesis 9 character with the navel morph cranked up to 100%, it reverts back to zero? The morph disappears and the Navel HD dial resets to 0%?
Hi. I am having the exact same issue.
Each time I load the scene the Navel HD dial goes back to 0%. I've tried reinstalling the Genesis 9 starte pack, no change.
Will keep an eye out, hopefully someone has a solution.
Which Navel HD property did you guys dial on earth ? The one shown in the 1st screenshot ?
Then open your Scene file with Notepad++, check if there's a Current Value correctly set... in the 2nd screenshot.
Besides, also check if you ever installed any products from 3rd-party sites including Navel HD morphs which have the same name/label as the above one from Daz Originals...
Thanks crosswind. My default was set to 0. I changed that to 100% and it solved the problem.
And yes, I am using the morph you showed in the attachment.
