Corners of the lips
Michal P.
I have converted my head morph from G9 to G8. I did rigging (I believe that is correct.). But when I open mouth, the corners of the lips are too much open and down in comparison with G9 (see attached images). Any hint how to fix it?
740 x 519 - 664K
717 x 523 - 685K
What mouth open property did you dial on them... Mouth Open or Jaw Open ? G9 has no official Mouth Open property but Jaw Open only... G8.0 has no Jaw Open but Mouth Open only....
So the better way is to check with G8.1 and G9 that have both FACS expressions, then dial Jaw Open property on them.
However, even if you do so, you won't get 100% same morph result as G8 / G9 have different topology / mesh density on Head... let alone Jaw Open property on them have different vertex positions ~~
There are about 30 "Adjustment" Pose Controls on the mouth alone, surely some combination will achieve what you are looking for.
I decided to create JCM (Joint Corrective Morphs) for "Lower Jaw / Up-Down". I feel that "Lower Jaw / Up-Down" set to 20 for G9 is corresponding to "Lower Jaw / Up-Down" set to 18 for G8F. I have attached picture where you can see the difference when "Lower Jaw / Up-Down" is set for G8F and for G9 in shape of G8F. I have also attached JCM morph (lighter color) picture which is in same position as G9 (darker color). The mouth (not lips) and teeth have to be removed from the JCM morph. I found this wideo helpful to set the JCM and to limit it only for my head morph:
