[Released] Hat Check for Genesis 8 [Commercial]
Quickly and easily create hair morphs to use your hair with different hats and caps, even sunglasses and hairbands!  Hat Check works by using a sphere, cylinder or cube to define an Effect Volume which you position over the hair.  Any hair vertices inside (or outside depending on the options) the Effect Volume will then be pulled close to the head of the figure.  Any hair vertex outside the Effect Volume, but within the feathering distance, will be pulled partially towards the head of the figure.
Hat Check creates 2 morphs for the hair based on the label of the "hat": one using the label name (e.g., "RS Fleur Hat") that controls all hair vertices inside the Effect Volume, and one using the label name plus "feather" (e.g., "RS Fleur Hat Feather") for all the vertices at the edge of the Effect Volume.
  • Quickly create hair morphs
  • Includes 2 scripts for creating hair morphs
    • Use Effect Volumes (Cube, Ellipsoid, or Cylinder) to specify the hair vertices to morph
    • Use Selected Vertices to specify the hair vertices to morph
  • Morphs can be saved separately or as part of the scene file
Morphs created by Hat Check are a Merchant Resource, which you can distribute with your Hair product.
1000 x 1300 - 1M
1000 x 1300 - 1M
1000 x 1300 - 1M
1000 x 1300 - 1M
1903 x 1000 - 2M
1000 x 1300 - 1M
1394 x 1000 - 818K
1394 x 1000 - 843K
1000 x 1300 - 532K
  • CrescentCrescent Posts: 329
    Is it just G8 or does it work for G9 as well?
    What's Included and Features
    • Hat Check for Genesis 8: (.DSE)
    • Scripts:
      • Hat Check for Genesis 9 Script
      • Hat Check Geometry for Genesis 8 Female Script
      • Hat Check Geometry for Genesis 8 Male Script
      • Hat Check Install Custom Actions Script
      • Detailed User Guide (.PDF)
  • LeanaLeana Posts: 11,785
    Description was most likely copied from the G9 version released some time ago: https://www.daz3d.com/hat-check-for-genesis-9
  • ElorElor Posts: 1,695
    The files list also has no mention of the Genesis 9 script:
    http://docs.daz3d.com/doku.php/public/read_me/index/105845/file_list
  • RiverSoft ArtRiverSoft Art Posts: 6,610
    • Scripts:
    It is a copy and paste error.  This is for g8 only.  I will let Daz know.
  • tsroemitsroemi Posts: 2,799
    I'm really happy this came out so fast after the G9 version, thanks! Landed in my library with the wishlist discount today. One of the BESTEST and most useful ideas of this year, the hat check yes
    You're welcome!  I am so glad you like it.
    FYI, a G3 version is coming too.  I don't plan to support anything earlier unless there was a lot of demand.
  • Should the scripts be compatible with Genesis 8.1, or is it an error that this generation is listed under Compatible Figures?
    I get the following error when using Genesis 8.1 figure:
