Is there a 'Reflection' Ground Plain?
Would like to know if there is a 'Reflection Ground Plain' that when placed at the ground zero you get a mirror reflection of your scene / character placed on it.
Idealy having a variety of textures as well eg small / large tiles, wooden flooring, fine gravel maybe.
  • ElorElor Posts: 1,891
    Applying a mirror preset / a very reflective material preset on a primitive plane should do the work just fine.
  • felisfelis Posts: 4,619
    Not sure what you are after.
    You can create a plane and make it reflect like a mirror.
    But how will you combine it with textures? You could make a tile layer where it only reflects on the tiles and not the gap between the tiles.
    Do you have a picture showing what you are after?
  • 3Diva3Diva Posts: 11,728
    Something like this might help if you have trouble setting up plane primitives to create reflections:https://www.daz3d.com/catcher-plus--shadows-and-reflections-for-iray
    It can be tricky to get surface settings to do nice reflections if you're not very familiar with the Iray surface settings, so a product like that might be helpful. :)
    There are also a couple more products to choose from depending on your preferences and what exactly you're after:
    https://www.daz3d.com/reflection-designer
    https://www.daz3d.com/sv-s-reflections-floor-iray-shaders
    https://www.daz3d.com/iray-hdri-toolkit
  • nemesis10nemesis10 Posts: 3,489
    edited December 2024
    I did a very quick render with a plane using one of the homestyle shaders (https://www.daz3d.com/homestyle-2-iray-shaders)  Though the render is very incomlete so i can go to bed, note that refelection shines a lot of light into the face of the character...
    1311 x 1040 - 1M
    Post edited by nemesis10 on
  • crosswindcrosswind Posts: 7,921
    Create a primitive Plane, setting its Metalicity to 1.0 in Surface pane will make it a specular surface (mirror). Then add any texture shader as you wish but don't set any rougness / bump / normal on it.
    2560 x 1392 - 3M
    Thank you 'crosswind' will try this out for suresmiley
    Oh, this is fantastic, thank you '3Diva'...great links and will look through these....still a beginner with a lot to learnblush
    This is great, thank you for taking the time to respond
  • sign.shopsign.shop Posts: 28
    Was not quite sure how to do this...still a complete noob...but thank you for replying 'Elor'
    Post edited by sign.shop on
    Thanks for your response 'felis'...there is plenty of information contained within this thread that is very suitable
