Tera's bedroom iray shaders
daer-thingdaer-thing Posts: 72
edited December 2024 in The Commons
According to product info [Tera's bedroom] this product is shipped with both iray and filatoon shaders, but when I load the scene it wants all sorts of filatoon stuff and in materials folder I can't find any iray options. Also, product page says that product is compatible with 4.22 daz, which I'm using but iirc filatoon is a 4.23 thing? (I might be wrong). My iray preview looks like the attached jpg shows.
Is it possible to use this product in iray mode? :(
1000 x 981 - 88K
  • TaozTaoz Posts: 9,971
    The Iray presets may be located in a different place in the library, I'd check the folder structure in the zip to see if that might be the case.
  • crosswindcrosswind Posts: 7,839
    Unfortunately the iray related info. on the product page is wrong... ( just stated as Toon style room...) There's no Iray preset at all other than FILA Presets in the package.
    Post edited by crosswind on
  • 3Diva3Diva Posts: 11,702
    If this product doesn't come with Iray presets you can put in a support ticket and ask for a refund and mention that they might need to update the part on the product page that says "Daz Studio Iray Material Presets".
    If you'd really like to keep it though and don't want to return it, you can manually delete the "Toon Outline" geometry shells on the furniture and other items and then add the Iray Uber Base to the surfaces to make the surfaces Iray. They won't look ultra-realistic since the materials aren't set up to be anything but "toon", but it should still be able to be rendered in Iray that way.
    Thank you for the ideas!
    Sad thing is that I like how busy and crowded this room is so will definitely see if it can be salvaged before trying the refund. :(
  • DripDrip Posts: 1,206
    Thank you! I think that is exactly what they did in one or two of the promo renders, which had some iray-ish reflections and highlights. The not-ultra-realistic materials might eventually work out nice for sci-fi scenes, which just happens to be very interesting to me.
