Genesis 8 issue
in New Users
Hello everyone! I am a beginner and have recently installed the program. I have some kind of error that for some reason does not display the genesis 8 model, but the poses, clothes and so on work without problems. At the same time, there are no problems with genesis 9. I need genesis 8 specifically to work on a specific character that I bought. Reinstalling packages and even the entire program itself did not help, can you please help me to solve the problem
2039 x 1327 - 215K
1852 x 1310 - 391K
Do you get an error message? How about in the log file (Help>Troubleshooting>View Log File) if you look at the end just afte trying to load the figure.
I have solved the problem. It turned out that genesis 8 for some reason referred to the onedrive folder. I changed the path in the Content Directory Manager and everything worked. Thanks for the advice (I didn't know that all the information is recorded in the log)
That is a Connect install - installed through Daz Studio - while your screenshot showed an instalaltion through Install Manager. You don't want both, they just waste disc space since the files go to different locations. If there is a Connect installation its files will be used in preference to anything from Install Manager, which is why the wretched OneDrive's usurpation of your content location caused an issue.
