Star Shaped Glasses?
Fabler
Is there a product out there with star shaped glasses?
I've looked around and haven't found anything...
Post edited by Fabler on
https://www.turbosquid.com/3d-models/3d-model-sunglasses-in-star-shape-1868160
https://www.cgtrader.com/3d-models/character/clothing/cartoon-star-shaped-sunglasses
I have some in my product library, but unfortunately, Morphing Glasses was a truly ancient product (pid 520) that is no longer available in the store.
Thanks for the links and info. I was hoping for an easy daz compatable product.
Maybe someone will put out a new glasses set and include a star shape.
So... Elton J.?
While these items are designed for VRoid, they are provided as FBX files, so you can import them into Daz Studio as well.
However, you will need to manually reconfigure the materials.
https://rxf.booth.pm/items/2897020
https://rxf.booth.pm/items/4492333
The attached image shows a render taken in Daz Studio using these products.
https://www.renderosity.com/freestuff/items/85212/rock-star-for-g8m-e-woman-and-d-girl
Thanks for the additional links, much appreciated.
For the FBX files after importing them into Daz, how do you reconfigure the materials?
If the Surface Groups of the imported FBX are properly separated, you can apply your preferred shaders to each Surface Group and adjust the parameters yourself.
If the Surface Groups are not properly separated, first use the Geometry Editor to separate them properly yourself.
@CES3D thanks, I'll give that a try.
