[BROKEN!] Product inclusion (to gen 9)
It's more likely a guess, but as I find more and more Items that "seem" to be broken, I have to make this one public! These different Items I installed over this year into a folder that has a purpose (clothings that are new). Since I  am using genesis 9, I want to make use of all the features a PA gives me without having the trouble myself, fitting everything to the gen 9 generation. I did deinstalled and installed of these products again today! So there has to be something wrong. The genesis 8 versions of these products are there and linked. They work. But the genesis 9 version not!
I have a setting of a scene, where it - is - important that these transisions work flawless. I cannot transfer the genesis 8 versions of them onto the genesis 9 figures in the scene. It's just to much, since the items would be "cloned" to multiple node instances. I also cannot "fit" or "manipulate" things in this sceene. It's loading shapes, adding materials, adding clothings onto the main figures and that is it.
Apart from my very performance-heavy scene I think it's only right to make this "public" so any PA get's the notification and any user/buyer can also take a look if they have similar experiences with chlothing items. It's not a small thing for me. I would need to transfer every Item one by one to genesis 9 AND check every item on multiple differend parts, that are known as "buggy" or let's call it complex and create odd or strange destructive behaviors in the process of transfering them over to the other generation. Even with these really nice scripts some different PSs provide to do that.
Anyways. The thing is, I pay for these products to - spare time - and I really want to have the features I pay for available to use! This is no error in my database, since I installed them again and again. If the DIM would be broken, this would happen not only to them. But it does! So these products (and many more items by the look of the smart content file search) seem to have problems getting into the database "the right way". I cannot use the product and the image is also missing. If I manage to content library -> products the product is there! The genesis 8 version of it too and is available to work with. The genesis 9 version not! The link is missing, even after a complete de-reinstall process.
Please check your own databases.
If there is an issue with the DIm (what may can create similar problems I guess), then it would be nice if at some point a problem like this would be fixed some kind of "reinstall this contend" process would happen, so we would know for usre now we can and should install our products again. I don't really know where the real problem is. But, I CANNOT file 50.000 support tickets for every product this happens. This topic is no ranting about PAs! Mistakes can happen. It's more likely an information for all to look into this. Some of you may install some products manually. But that I also CANNOT to for this mass of products I see like "broken" in my database. Everything else works fine, many other products work as intended and are in fact also created like the broken ones. So there has to be a reason why this happens and it cannot be on my end, except the DIM is broken right now. But I do not believe that, since I installed a lot lately which works great and without problems.
These are the products I sorted out. But again, that are not all of them! I just stopped trying to fix them by uninstalling and installing those that are broken. Sady I did not list all of those I tried to fix before. I was at least 2-3 hours doing this. With NO souccess it seems. Some of these products are just seperated products of a complex outfit. But is does not matter. Even for any kind of part it's not working
dForce MK Strapless Tight Dress for Genesis 9 (Cv)
dForce Hellen Outfit and Weapons for Genesis 9 (Cv)
dForce Cozy Winter Outfit for Genesis 9, 9, and 9 (Cv)
dForce Mabel Outfit for Genesis 9 (Cv)
dForce Autumn Breeze Outfit for Genesis 9 (Cv)
dForce Brooklyn Outfit for Genesis 9 (Cv)
dForce Meiying Chinese Outfit for Genesis 9 9 (Cv)
dForce X-Fashion Urban Outfit for Genesis 9 (Cv)
Work Day Outfit for Genesis 9 (Cv)
Cool Lace Outfit for Genesis 9 (Cv)
Trench Coat Outfit for Genesis 9 (Cv)
dForce Hayden Outfit for Genesis 9 (Cv)
MK Flounces Outfit dForce T-Shirt for Genesis 9 (Cv)
MK Flounces Denim Outfit dForce Skirt for Genesis 9 (Cv)
Gothic Style Outfit V2 Gloves for Genesis 9 (Cv)
Dark Whispers Outfit for Genesis 9 (Cv)
Cold Weather Outfit for Genesis 9 (Cv)
dForce Christmas Isabella Crop Top Outfit for Genesis 9 and Genesis 9 (Cv)
BW dForce Moonlit Magic Outfit (Cv)
  • ElorElor Posts: 1,664
    Looking at my own library, (Cv) was added after the name of a couple of products I converted with a RSSY converter.
  • It is a little hard to figure out what the issue is from your post, but I guess you have products that are for Genesis 9 installed but they do not show up in Smart Content with a Genesis 9 figure selected. If that is the case do any Genesis 9 items show up? If not it may be a metadata issue - something usurping the base compatibility from Genesis 9 so that products don't see it as a compatible item; if so then reinstalling the Genesis 9 Starter Essentials may help. If that is not a correct interpretation of your issue, please try to provide a succinct and focussed description of what is happening.
  • LeanaLeana Posts: 11,783
    edited December 21
    None of the products in the list actually has a G9 version in the store, those are converted items. So whatever problem OP has is most likely due to the conversion.
    Post edited by Leana on
