Turning off the illumination of a light source, but leaving a reflections from this source?
Hello. I want to create a small white dot in the character's eyes, for this I placed a light source that is reflected in the eyes. But I don't want this light source to illuminate anything. I just need a white dot in the eyes. What is the best solution for this?
  • crosswindcrosswind Posts: 7,843
    Catchlights can be either made by using a light source at a certain place in front of the figure, as you did...or using a texture map in Cutout Opacity slot on Eyes' surfaces. In your case, if you turn off the light, it won't emit light anymore, then how can it be reflected in the eyes ?
    So, you may go for the 2nd way... by creating a mask map and assign it to Cutout Opaciy on EyeMoisture surfaces on G9, or Cornea surface on G3/G8 ~~
    2018 x 1292 - 2M
  • CES3DCES3D Posts: 128
    When adding catchlights to the eyes in a still image, you can also draw them in using photo retouching software such as GIMP or Photoshop.
    2063 x 1210 - 2M
    Yea, post-work can always work well !
    Thank you. Could you explain a little more about how to create the right mask, please? Do I need to manually make a fully transparent (if i undestand correcly, that the black color in your image is transparency) png image and paint reflections with desired color and form (in your image it's white)? How do I know what size an image should be, i need to use default cornea texture as a draft?
    And do I understand correctly? This mask is basically just a custom texture for eyes, it's not an actual reflection of some light source? So if i want to change the position of white dots, i need to edit this texture again?
