Looking for an example of G8 character using Mimic in Carrara
Hey guys,
I am thinking of buying Carrara so that I can using Mimic on G8 characters, but I would like to see an example that has actually worked first.
or
If they had a trial version, then I could see for myself
I have submitted a couple of requests on the subject, but both of them are still in open status without a response. Can anyone shed any light on this subject?
I have seen plenty of examples with older characters, but yet to see an example with G8 characters
Thanks in advance
Greetings. Although I can't answer your question directly as I have not done it, here is some information you would probably want to be aware of before buying Carrara.
G3 and G8 are the least compatible generations with Carrara. There was a problem with a toe joint and with a typo in the rigging which required a work-around character available through Renderosity. Otherwise, Carrara would crash upon loading those specific figures. Unfortunately, the amazing artist who identified the problem and provided the partial solution is no longer with us to provide guidance on usage. Here is a link to the file necessary to load the G8.1 figure in Carrara without crashing.
https://www.renderosity.com/freestuff/items/88523/carrara-presets-for-genesis-81
On the other hand, the Victoria/Michael 1-4, 5, 6, and 9, and the Genesis 1, 2, and 9 figures do load in Carrara without the workaround mentioned above.
