List Views?
Seven193
Is there example script code showing how to populate a list view with nodes?
I would like to re-create this partcular list view. It lists a hierarchy of nodes with checkmarks by them. And there is no visible divider in the column header:
No basic examples about list views can be found in the docs:
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/listview_dz
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/checklistitem_dz
A lot of those are custom objects built from multiple sub-objects, rather than stock objects. I don't know if that applies here but it would not be a surprise.
Well, I had to piece together from some random scripts, but got something working.
Found out how to get a single header with no divider line:
treeWidget1.header().setStretchEnabled(true,0);
A more complete example:
function
Add_Tree_Item(treeView, nodeText, bCheckFlag) {
// create checked item
var wTreeItem = new DzCheckListItem( treeView, DzCheckListItem.CheckBox );
// Set the text
wTreeItem.setText( 0, nodeText );
// Expand the item
wTreeItem.open = true;
// checked (Boolean)
wTreeItem.on = bCheckFlag;
return wTreeItem;
(function() {
// Get the current style
var oStyle = App.getStyle();
// Get pixel metrics from the style
var nMargin = oStyle.pixelMetric( "DZ_GeneralMargin" );
var nStepSize = oStyle.pixelMetric( "DZ_TreeStepSize" );
// Create Dialog Box
var wDlg = new DzDialog();
wDlg.width = 276;
wDlg.height = 308;
wDlg.caption = "ListView Test";
var treeWidget1 = new DzListView( wDlg );
treeWidget1.setGeometry( 10, 30, 251, 231 );
treeWidget1.addColumn( "Nodes" );
treeWidget1.setSorting( -1 );
treeWidget1.itemMargin = nMargin;
treeWidget1.treeStepSize = nStepSize;
Add_Tree_Item( treeWidget1, "Item1", true );
Add_Tree_Item( treeWidget1, "Item2", true );
Add_Tree_Item( treeWidget1, "Item3", true );
var pushButton1 = new DzPushButton( wDlg );
pushButton1.setGeometry( 100, 270, 75, 25 );
pushButton1.text = "Accept";
pushButton1.objectName = 'pushButton1';
wDlg.setAcceptButton(pushButton1);
var pushButton2 = new DzPushButton( wDlg );
pushButton2.setGeometry( 180, 270, 75, 25 );
pushButton2.text = "Cancel";
pushButton2.objectName = 'pushButton2';
wDlg.setRejectButton(pushButton2);
// Display the dialog box
var bResult = wDlg.exec();
if(bResult) {
else {
I am told that using DzBasicDialog, rather than DzDialog, with its AddWidget() method will be better as you will get auto-adjustment and default buttons.
If the random scripts included the samples make sure that you respect the license terms, and likewise for any other scripts you use.
Why does Daz include QT Designer in the Daz Studio package if not to use it to create dialogs? I cannot visualize an auto-adjusting dialog, nor can I find any good examples.
And what if the script was generated by AI like chatGPT? Not that it was, but it's a possibility.
The samples use Basic Dialogue, rather than Dialogue. As far as I know Qt designer is part of the standard footprint, but in any event I don't think it was "never use dzDialog but rather "DzBasicDialog" is better for this kind of thing.
It isn't soemthing I have done, but apaprently Qt Designer gives UI files which then need to be accessed through another object - I think http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/uiloader_dz
Don't forget that if you point ChatGPT to the Daz Scripting docs it is still bound by the terms of any samples it samples.
I've never not used Designer to make dialogs, and set up custon build steps in VS to generate the ui.h and .moc files. I've never encountered any issues.
I mentioned QT Designer because it creates all of its widgets with fixed geometry (pixel) values. From a typical .ui file:
<widget class="QPushButton" name="pushButton_2">
<property name="geometry">
<rect>
<x>100</x>
<y>140</y>
<width>75</width>
<height>25</height>
</rect>
</property>
<property name="text">
<string>Accept</string>
</property>
</widget>
And I did come across some forum comment mentioning fixed values are bad for high DPI monitors. So, does that mean using QT Designer is now bad practice for designing dialogs?
I didn't think of that. I wonder if the behavior you researched is also true for the versions of Qt that support high DPI?
