Diffeomorphic - Selectively importing DAZ Favorites morphs?
DrGonzo62
Hi,
Is it possible to selectively import a single morph for a figure later, or is this limited to either all of DAZ Favorites or none?
Just trying to avoid loading times for a lot of unnecessary morphs along with what I actually need.
Thanks and Happy Holidays!
545 x 410 - 50K
Post edited by DrGonzo62 on
I'm not sure to understand, of course you can change the daz favorites and import a single morph. Or import custom morphs. Or import dbz morphs. Or import favorites morphs. In general daz favorites are used with easy import to load a full figure as we want her, then we can re-use daz favorites with a different set if needed.
https://bitbucket.org/Diffeomorphic/import_daz/wiki/Setup/Morphs
Sorry if I didn't make myself clear.
If I export a figure from DAZ with let's say 50 often used morphs tagged as Favorites, and then import the figure with DAZ Favorites enabled, it takes a very long time to import that figure.
Is there a way to not import DAZ Favorites when initially importing that figure, but later import only selected Favorite morphs when needed, instead of having to import all of the DAZ Favorite morphs at once?
In the image below for example, I only needed the 3DU Hip Crouch morph from the list of custom morphs, but I had to import all of them instead, which takes a very long time.
There's a lot of going back and forth from DAZ to Blender in order to change clothes or hair of a figure, so long figure import times are an issue.
Thanks!
You seem to use blender the same as you use daz studio, that's just bad. In blender we don't want to import pose morphs as we use a IK armature for posing and animation. This usually brings daz favorites to a few shape morphs for geografts. However to reply your question in your case you may want to use favorite morphs instead of daz favorites, the name is similar but favorite morphs lets you create your own lists inside blender.
I'll check it out, thanks Padone!
