Adding favorites to default G8.1F
I have some favorites that I'd like to be set in the default g8.1F figure since use them extensively. How would I go about doing this?
Post edited by Second Technician Rimmer on
  • felisfelis Posts: 4,595
    Highlight the character and right-click, 'Mark to Favorites?
    Your email is used as username. Might have come when doing other changes at your account.
  • crosswindcrosswind Posts: 7,806
    edited December 2024
    After setting the Properties to Favorites, you can save G8.1F figure as a Character Preset or a Scene Subset. Load the preset or subset each time instead of loading the default G8.1F Base / Dev Load.
    Edit: If you use DS 4.23, there's a new Preset > Persona Preset, saving as a Persona Preset will also do.
    Post edited by crosswind on
  • We were able to get your username fixed,. since we seem to recall you used to have it more-or-less like that.
    Do you mean morphs? Set them as favourites using the heart icon (which I assume you know) and then save a new character preset - if you use that to load the figure, rather than the Daz-supplied one, it will still have the favourites set.
  • Thank you for that, Richard. It's perfect like this :) I'll follow your advice. Ithought it was possible to alter the Daz-supplied one but I guess that would come with its own drawbacks?
    If nothing else, and I am not sure if there are other potential issues, an update would then kill the customisation (which should not, at least in general, happen with the character preset approach).
  • Aha... indeed, good point.
