DENOISER FAULT ?
mateskulalamateskulala Posts: 128
edited December 2024 in Daz Studio Discussion
hello I have a problem with denoiser I use it to render frames faster but the problem is basically the same as when I solved it here, I updated my graphics card to a new upgrade and it does it again only this time as if the error is in the denoiser .. do I have to put the control on the one where the error did not occur there ? with the old update nvidia driver everything is always fine so do you have any IDEAS ?  ? I'VE BEEN USING A DENOISER FOR A LONG TIME, THERE HAS NEVER BEEN A PROBLEM  THIS IS HOW I STILL HAVE THE DENOISER SET
EVERYTHING GOES WELL WITH THE DRIVER VERZION  561.09
ERROR APPEARS WITH NEW DRIVER 566.36
1518 x 232 - 47K
1534 x 183 - 36K
211 x 207 - 13K
Post edited by mateskulala on
  • crosswindcrosswind Posts: 7,806
    Post Denoiser was designed for Iray rendering with GPU...in the 2nd screenshot above, it seems that you rendered with CPU rather than GPU... so Denoiser failed to work. 1stly check if you ran out of VRAM ~
    If 566.36 doesn't really work for your case, just roll back to the older driver that worked for you...
  • HOW DO I CHECK MY RAM ? WHERE CAN I FIND IT? AND I USE PURELY ONLY THE GPU, THE CONTROLLER DOES IT AGAIN, I HAVE CHECKED ONLY THE GPU AND AFTER A FEW HOURS it switches to the pcu again, it seems ok, so I'll go back to the old controller, but they could fix it now, or will it never be fixed again?
  • jjoynerjjoyner Posts: 634
    TechPowerUp’s GPU-Z is what many Windows users (myself included) use to get more information about GPU memory usage that what the Windows Task Manager provides.  It’s a free download at https://www.techpowerup.com/download/techpowerup-gpu-z/ .  If you’re a Mac user, you might find a desirable alternative to GPU-Z at  https://alternativeto.net/software/gpu-z/?platform=mac
  • iRAY eat more and more VRAM for each release so there is not anything to "fix", thats why it may work on the older one, the message is not an error, it just say that you are using CPU and denoiser will not work.
    So no, you cannot expect a "fix" unless you get a GPU with more VRAM.
  • mateskulalamateskulala Posts: 128
    so as he got more VRAM I have to buy a new graphics card or if I bought a whole new PC ...
