backup problems
Hello everyone, I hope you're all well, I'm having a problem with my daz studio 4.23 since I upgraded all the work I record is saved correctly but when I reopen the file to work on it strangely I only have large grey squares whereas all the Data base is present I don't really know what to do I'll take any advice or help thank you!
  • felisfelis Posts: 4,595
    Not sure what you mean with "upgraded all the work".
    If you just have grey boxes, it means it can't find the data files.
    Try to look in your log (Help > Troubleshooting > View Log) where it should give more specifics to what is missing.
  • SofaCitizenSofaCitizen Posts: 1,949
    As felis has said the grey boxes mean that the data files cannot be found - thus the database (CMS) is not something to look at. Simply upgrading the Daz Studio application should not have changed anything (unless maybe you are upgrading from an uber-ancient version that did things in a different way) and so the issue you are facing is most likely not connected to that. Just a co-incidence.
    Check to make sure that all your content libraries are still configured in Daz Studio, make sure that OneDrive cannot touch any Content Library folders. If you are a premier subscriber or install via Daz Connect (within Daz Studio) then make sure you are logged into your account within Daz Studio - if you are NOT a premier subscriber and install products via DIM then make sure you do not log into your account withi Daz Studio.
    If those steps do not help then post a picture of your content library config, the error messages seen and some more details about how you install content and anything else you may have done since those scenes last worked as intended.
