How to create a shortcut or write a script?
Is there a way to write a script or define a keyboard shortcut to "Restore a figure shape"? I often redefine a figure's shape in the zero frame and then have to reapply it over and over in each subsequent frame. After about 50 times it's rather tedious. Seems like one could find a way to do it for all the frames once you're happy with it.
(If ths isn't the right FORUM to ask this in, I assume the moderators will move it....)
Thanks
  • crosswindcrosswind Posts: 7,806
    Press F3 in DS, in Action list on the left, you can find Restore Figure Shape under Parameters. Assign a shortcut as needed.
  • Richard HaseltineRichard Haseltine Posts: 102,129
    You shouldn't usually need to do this anyway, unless you have keyed the shape properties in every frame for some reason. By default keys would be set in frame 0 when adjusting the shape there and would carry over throughout the animation in the absence of other frames.
  • It seemed to work, so thanks.
