Hairshop 1.0 and DressShop 2.0
dash2128dash2128 Posts: 714
Do [Hairshop 1.0 and DressShop 2.0] these products only produce hairstyles and clothing G1?  Or do they produce items that work on all Genesis figures (G1-G9)?
I wasn't sure, because they just say: compatible with Genesis.
1115 x 803 - 92K
1325 x 845 - 125K
  • ImagoImago Posts: 5,235
    You can adapt anything for Genesis1 (which is the supported figure there) to any other Genesis Base from 2 to 9 using the AutoFit options.
  • dash2128dash2128 Posts: 714
    edited January 2
    Thanks for replying?
    'AutoFit options'?  How do I do that?
    Post edited by dash2128 on
  • felisfelis Posts: 4,595
    Autofit is a part of Daz Studio.
    If you fit an item to another generation that it was saved for, there will come a pop-up asking which generation it was made for, and then DS will run a transfer to the model you are using. Autofit can cause some distortions, which many will smooth out in a modelling program. Smooth inside DS can also help.
    But for something like hair, I would assume it should fit fairly ok, as it primarily is on the head.
    Oh, okay!  Thank you!  Now I know what was being referred to.
    Autofit doesn't seem to be a 'do-it-all' kind of feature.  Some items, it doesn't seem to be able to adapt and fit.  Other times, it doesn't offer the correct the correct option- usually a female G8, G3 or G2, for some reason.  It usually always offers the male, though.
    Glad to have it, though!  I downloaded some product that is 'supposed' to fit wardrobe between Genesis types, but I haven'thad the time to figure out how it works, yet.
    Thanks again!
