Goz works from Daz to Zbrush, but not from Zbrush to Daz
Good morning everyone.
I searched the Forum, I found only problems similar to mine, but none of them dealt with this issue specifically. I also tried some solutions suggested in other posts, but nothing.
I just updated my version of Daz3d to 4.23. Reinstalled the Goz Plugin for the new version. And of course it doesn't work. If anyone had the same problem as me and then solved it, I would be eternally grateful. I've been struggling with this thing all day.
  • crosswindcrosswind Posts: 7,806
    In ZB, under Preferences > GoZ, have you tried updating path to Daz Studio Public Build application ? Did that work ?
  • Thanks for the quick reply first of all. It's one of the attempts I've already made, but in Zbrush preferences Goz doesn't appear. While instead the command to return to Daz3d appears... only that when I go to click, it doesn't work. I know I'm doing something wrong, but I don't know where.
    If so, then you can try:
    0) Uninstall GoZ plugin in DIM.
    1) Fully close ZB, go to ZB's application folder, there's sub-folder: Troubleshoot Help, run GoZ_for_ZBrush_Installer_WIN.exe.
    2) Reinstall GoZ plugin in DIM.
    3) Open ZB, check if you can see GoZ under Preferences and update the path.
    Nothing to do. I did what you told me. One thing has actually changed: Goz still doesn't appear in the preferences menu but just in case I tried to edit a Daz character and send it back to Daz via Goz; a dialog box opens suggesting I do exactly what you tell me.indecision
    Hmm... odd. What's your ZB version ?
  • crosswind ha detto:
    Hmm... strano. Qual è la tua versione ZB?
    Zbrush.2024.0.1
    Go to :C:\Users\Public\Pixologic\, can you find a sub-folder: GoZBrush ?
    And have you tried uninstallation / re-installation of ZBrush ?
    I checked and the folder is there. Actually I uninstalled and reinstalled only Daz3d, because the problem arose as soon as I updated to the latest version of this program. I didn't think to do it with Zbrush. I do it.
    Nothing. Unfortunately it doesn't work. I uninstalled and reinstalled Zbrush. I reinstalled Goz but nothing. At the first start Zbrush asked me to find the location of other programs (that I don't even have) but from Daz3d, nothing. I can only thank you for the availability you have shown so far.
    I don't understand... it shouldn't behave like that. Did it work before... i.e. haver you seen GoZ under Preferences before ?
    Or you may ask for Customer Support from ZB... it's not the issue of Daz Studio...
    992 x 1294 - 87K
    Non capisco... non dovrebbe comportarsi così. Ha funzionato prima... cioè hai visto GoZ in Preferenze prima?
    Oppure puoi chiedere al Supporto Clienti di ZB... non è un problema di Daz Studio...
    Sorry for the absence, but here in Italy it was late at night, I went to sleep. This morning I woke up and checked again. This time I found Goz in preferences. Probably the stupid one was me who couldn't scroll through the entire menu. But I have to choose the path manually and I don't know which folder or file to select.
    crosswind ha detto:
    Ok...I solved it. I can only thank you immensely for your availability. You helped me solve a problem (probably for an expert, a trivial problem) that had blocked me for 2 days.
    Thank you and have a good life!!!
    Okay, that's great !
