dForce clothes on a character fall to the ground
My dForce outfit falls to the ground when I run simulation. It happens every time. I'm using this outfit https://www.daz3d.com/dforce-jump-tech-outfit-for-genesis-9 with Genesis 9 character. I'm also using default settings of simulation, screenshot in the attachment. How do I make this work properly?
615 x 788 - 468K
383 x 492 - 29K
  • SofaCitizenSofaCitizen Posts: 1,949
    edited January 3
    I have that outfit so I can try a quick test. In the meantime, try it with the hair hidden (or excluded). Also, I assume you did not use "Simulate Selected" with just the clothing selected?
    EDIT: Created a new scene, loaded G9 and added the Base Feminine to 100%. Added the outfit to the figure and hit the simulation button and the clothing draped as expected so was not able to reproduce any error. I assume you did actually fit the Outfit to the figure rather than just load them both at the scene origin?
    Post edited by SofaCitizen on
  • murgatroyd314murgatroyd314 Posts: 1,538
    Check the Parameters tab, and make sure that Genesis 9: Display: Visible in Simulation is turned ON.
  • bronyswvgbronyswvg Posts: 2
    Simulation with hidden hair worked out. Everything works as it should now. Thank you :D
