V3D FilaToon Converter: Okay, What am I Doin' Wrong?
This is one of the easiest to use tools I've come across for doing a very difficult transition into toon territory.
The problem is how the heck do you render the converted image? The first time I used it (here) no trouble. Since, it will only print an Iray version no matter what the Viewpoint's showing me.
What am I doing wrong?
kmw
1909 x 1027 - 1M
  • crosswindcrosswind Posts: 7,806
    It's no iray version but just filament. Its skin textures as well as SBH were not designed for being used with filatoon shader...
    If you want to make a toon or anime lion, there'll be more work to do...and it's irrelevant to the converter.
  • barbultbarbult Posts: 24,679
    edited January 4
    You need to go the the Render Settings pane and change the render engine from NVIDIA Iray to Viewport. Then it will render the filament view you see in the viewport and you can save it as an image file.
    Post edited by barbult on
  • kmwkmw Posts: 29
    Outstanding! Got it work.
    Thanks, crosswind and barbult.
