Error
people, can I still snort this scene or is it completely gone?
1265 x 739 - 101K
  • CES3DCES3D Posts: 123
    What file were you trying to open? Was it a scene file?
    First, how about checking the log file as instructed in the error message?
    1105 x 558 - 266K
  • mateskulalamateskulala Posts: 128
    yes it is a scene. I'll take a look when I get home now I'm traveling to work. I just wonder if there is a way to reverse it. I'll check the error and get back to you right away.
    this one ??
    1348 x 571 - 75K
  • Richard HaseltineRichard Haseltine Posts: 102,127
    %appdata%/daz 3d/studio4/log.txt
    Paste that into the file browser's address bar and the log should open in the default application for .txt files (Notepad if you haven't picked anything else).
    I'm sorry, it's too complicated, you wrote it to my dull head. I don't understand I'm sorry
    it opened me for sure what I sent it on the picture is a logfile
  • frank0314frank0314 Posts: 14,244
    Browse to this location C:\Users\(YOUR NAME)\AppData\Roaming\DAZ 3D\Studio4 and look for the log.txt
    i already did what now ?
    it shows me this error only
    1538 x 580 - 111K
  • felisfelis Posts: 4,595
    That error looks to me as a Connect error not related to the scene file.
    Try to attach the log as a text file.
  • crosswindcrosswind Posts: 7,806
    edited January 16
    Wrong product GUID shouldn't stop DS from opening a user-facing DUF file... If you were opening that "bad prion 1.duf", the file now locates in your OneDrive folder, you may try copy/move that file to another disk, then open it. Or, open that file with Notepad++ to see if the file is corrupted.
    If the file is compressed, firstly uncompress it via DS > Window > Panes > Batch Convert.
    Post edited by crosswind on
    I tried that, I guess I have to accept that I can't save the scene, I guess I know what happened, I ended the scene and saved it, but I can't wait and immediately started loading the next one and probably there was a mistake
    Saving process and Opening processing are totally separate routines... they shouldn't bring issues to one another. Have you checked if the file is corrupted ?
    I ever saw a case in the forum, that a folk's hard was damaged to some extent, then some files were not able to be re-opened.
    How do I find out, please?
    As I said above: Uncompress DUF file firstly  via DS > Window > Panes > Batch Convert. Then open it with Notepad++.
    Or you can attach the DUF file in here if you don't mind. We may help to check.
    but it's an 18+ scene so
