Legacy UV plus different UV material?
RevokedRevenantRevokedRevenant Posts: 23
edited January 18 in Daz Studio Discussion
Greetings,
a quick one: can i use the product Legacy UVs to apply a G8F skin texture on G9, and then apply a different material, like a tattoo, natively made with G9 UV? if yes, how?
Thank You in advance!
Post edited by RevokedRevenant on
  • crosswindcrosswind Posts: 7,806
    Directly... ? Nope ~ because UV Sets have to be ALL set as G8F on G9 and its Legacy surfaces. For instance, if you want to use G9 LIE tattoos with Legacy UVs, You need to convert G9 texture maps to G8F, with Map Transfer (depending on the tattoo positions...). Then assign the converted maps in LIE.
  • Richard HaseltineRichard Haseltine Posts: 102,127
    As long as it doesn't affect the graft areas you could aply it to a Geometry Shell, which can have its own UV selection. But of course the grafts will be in the shel, and I don't think they have the default UVs (though it would, for this kind of thing, be useful if they did).
