Daz Studio Installation
sulivaracesulivarace Posts: 18
edited January 25 in New Users
Installation of daz studio
I had already succeeded a few years ago, then I had to stop using it and then I decided to come back to see the changes but I confess that I have a lot of difficulty.
I’m blocked at the very beginning, with the installation of daz install manager and the following error,
"Daz install manager cannot be run with elevated permissions"
when I try to run it after installation.
I have gone through the topics on this forum and I think I have exhausted all the solutions proposed.
I tried to run it as administrator, give it all the privileges from the parfeux, I also tried to launch it from the command invitation.
There is another solution that I did not try but I would like to avoid changing the registry.
Is there a solution to install daz Install manager normally? or if someone has official information or links to try other solution I am a taker.
I forget, I use windows 11 and up to date.
Post edited by sulivarace on
  • Richard HaseltineRichard Haseltine Posts: 102,109
    It isn't asking for admin permissions, it is saying it shouldn't have them - if you are installing from the master admin account*, don't; if you hve UAC switched off, switch it on.
    * a standard account with admin privileges is fine, as long as UAC is on so that you get prompted for permission when running an installer or accessing protected folders
