G8M expressions & 8.1 animations Q
Hi I am not sure if this is a G8M vs G8.1M thing or what.
I am using a G8M character on the Rock Stars drum kit with the G8.1M animations for the drumming which works fine.
Unfortunatly I am unable to load & keyframe expressions (G8M expressions) onto the character so the drummer just ends up looking bored.
Is this an incompatability between v8 (character/expressions) & v8.1 (animation) ?
I hope that made sence.
Thanks;)
  • Richard HaseltineRichard Haseltine Posts: 102,770
    If it is a Genesis 8 Male it should take Genesis 8 male expressions, though check that they are not dependent on the Genesis 8 Expressions pack if you don't have that installed (some sets go to the pose cotnrols from that set, rather than directly to the morphs/bones on the base).
  • crosswindcrosswind Posts: 8,090
    As long as the G8M expressions product you used call Base Pose Head properties, it should work even without this product : https://www.daz3d.com/genesis-8-male-expressions
    Name the product if you're not so sure ~~
