HeadShop Pro 2025
Hello. I seem to be having an issue with HeadShop Pro 2025. If I use a Genesis 8.5 or Genisis 9 model, I get a texture error. When I do use a Genesis 8, 8.5, or 9 model, I get a "no image detected" error. Has anyone else had this problem, and have you been able to solve it?
726 x 793 - 100K
  • Richard HaseltineRichard Haseltine Posts: 102,770
    Moved to Techncial Help as it is not a Daz Studiuo application topic, rather a plugin.
    Please put the Viewport in a non-texturesd mode if you are going to show a nude figure, or just crop out the message box.
    Should one of the "do"s in your post be a do not?
    I am not surprised that the image in your other screenshot gives an error - it is cropped in very tightly, and is rotated on its side. You probably need an image the right way up and showing the full head.
  • Catherine3678abCatherine3678ab Posts: 8,402
    edited January 26
    8.5?  Did I miss something? 8, 8.1, 9
    Anyhow, yes, definitely as Richard says, use proper square photos of the entire head [like passport type]. A high contrast between the background and the face helps too.
