Daz 4.23: force change character appearance?
[google translate]
Hi.I learned that you always have to keep the old version of a program that you use during the development of a project on Blender for  kepps addons
I didn't think I needed it here too. Each of my saves no longer shows the same character. As you can see in the images, made at different times and following the upgrade, they are the rendering of the same character, but that is no longer the same. This has occurred in all the saved files. Files that I haven't touched for a long time and I can't bring it back to the original appearance.
 I would like some advice if possible.
  • GordigGordig Posts: 10,162
    Scenes in DS are basically just a big list of references. When you load a saved scene, it re-applies all the references to geometry, textures, morphs, etc. If morphs have been uninstalled or are otherwise not immediately available to the program, it will load without that morph applied; if, on the other hand, a new morph has been improperly saved with a default non-zero value, it will apply that morph to all characters of the same figure. Load a default (or preferably dev load, if available) of whichever figure you're using, go to the Currently Used heading in the Parameters pane, and look for anything that shouldn't be there.
