Texture problem
stephane.romastephane.roma Posts: 0
I created some characters with Daz 4.0 Pro
I saved them in Daz format, but when i want to re-open these files, the textures look offset, like you will see in the pictures attached.
Can you help me?
Thanks.
1688 x 1018 - 696K
    It looks as if the wrong UV set is being used. Select one of the affected areas with the surface selection tool, then go to the Surfaces pane and see which UV set is being used.
