How to save IRAY preview images directly
May I ask, if I have got the desired result in IRAY preview mode, can I save the preview image directly? I don't want to re-render it.
  • crosswindcrosswind Posts: 8,084
    Under File menu, Save Last Draw...
  • kyoreonakyoreona Posts: 185
     Thank u panda ! That helps a lot !laugh
     Dear cute PANDA , I can't wait to do the test, there seems to be a small problem, is there any way I can control the resolution of the graph?
    No problem !
    But you have no way to control the resolution but just Viewport size in DS...on which the saved Draw will depend. If you go to Render Settings > General, choose Active Viewport in Dimension Preset(Global), you'll see the resolution in Pixel Size. That'll be the resolution of the saved Draw.
    Certainly, if you have higher resolution from your monitor, e.g. 4K or 8K, the resolution will be much higher proportionally.
    heartthank you !
    You're welcome! laugh
